Question
one; I stepped my mast this morning for practice (novice sailor) and found the forestay turnbuckle was very hard to pin in first or second hole anchor plate.
How does the turn buckle adjust? There is no nut lock on top?
The white tape on the upper part of turnbuckle, was removed by a fellow sailor, that went with me on a different sail.I dont know what or why he removed it. Only know what it looks like now.
There still is a white tape on bottom turenbuckle ,with what appears to be safety wire ?
Question
two;
I also run the mast sheet block and tackle, used for raising mast w Gen pole, back to the port side wench, from the anchor well pin, by tieing a dock line to the main sheet line.
The main sheet line well not reach by itself ...not long enough.
This allows me to use the wench/w handle to easy raising mast. Of course I a can pull a lot of the line through the wench by hand with out handle use.
Is this a bad practice to get into using wench, or is there a better way?
txs in advance ..you guys /gals are the real deal.....fair winds .
Question
