Brian K. Borchers
Message: I have a tall rig 1990 Catalina 28 (hull #20) with a single (non split) back stay. Does anyone know what the proper back stay tension and shroud tension should be for this rig (actual lbs.)? Also, do you suggest adjusting the back stay first and then the shrouds? Thank you; Borchers@net1plus.com From: Brian K. Borchers
