Bill, if that's true, I think the hollow fiberglass beam would need to be repaired after replacement material is installed so you have that tensile strength on the bottom of the beam. Has anyone done a calculation on the compressive strength of that foam core material above, to be sure that installing a smaller aluminum shim works? I'd like to know what the material is. Fiberglass has extremely high compressive strength of about 20,000 psi, rigid foams are around 25 psi (assuming polyiso or XPS, but I don't know what the material is), and douglas fir perpendicular to grain is around 700 psi, dry.
I'm seeing some repairs where people go with a 4"x4" shim, and some people are installing a wider aluminum shim, maybe 12" wide. It seems like if the shim only needed to be 4" in the first place, Hunter would've just installed a 4" shim. Based on the size of the aluminum plate and length of that wood, it seems that they determined you really need to spread the load out to avoid damage to the core material. Maybe it works with less, but you could be seriously cutting down on your safety factor with a small shim. Also with the cut fiberglass beam, this could seriously reduce it's strength if not repaired, but I'm sure there is some load transfer so that's why it may look ok.
Without having more information, I'd feel most comfortable going back in kind. That would mean installing a member the same length as that original wood to spread out the load onto the foam above, then repairing the fiberglass beam completely, and having the compression post bear on the underside of the beam.
If I did an underside repair, I'd have to pay the yard to repair the fiberglass beam below, and also to repair the damage to the fiberglass above from where the spinnaker chock was removed. The cost to do this could rival doing a 100% topside repair, where they basically gut it down to the fiberglass beam, and fill the entire area solid with fiberglass. Either way, I'm not getting out of this for less than a couple thousand dollars.
