1987 Hunter 31 Mast Step and Deck Damage
Just a snug fit, and sealant 3M 4200 applied to the pipe. Stuff the pipe into the hole with the sealant around the pipe. Add a bead of sealant around the base and pipe smooth and let set. All you need. When you attache the mast make sure the weep holes are clear and that you routinely clear the weep holes once or twice a year. If you see water again then you know you waited too long to clean your weep hole.
Oct 20, 2016
56
Hunter 31 Seattle
What about the top of the PVC pipe? It's pointed straight up, and I have a lot of water inside the mast coming in from a bunch of places. I could see water dripping straight down that PVC pipe. Why not fabricate a 180 bend in the PVC pipe, so wires go up and then down? It would seem much better than having a giant hole facing upward. That would eliminate the need for any hose. I could just have a PVC pipe with a 180 degree bend, extending several inches above the weeps.
I may also go look at the mast and see where I can seal up. I'm not sure if there are caps I could fabricate to cover all these entry points for the rigging that are likely a big source of the water getting in. Or I could goop everything up with sealant since it's just shedding water and not the last line of defense like the PVC pipe.
Nov 6, 2006
10,256
G 10 is great but ya can't find it easily in 2.5" thickness .. yes you can laminate it but how good is your bond? I had access to some solid chunks of aluminum and a friend's milling machine.. I made a balsa block model to fit precisely where/how I wanted, then made the aluminum to the dimensions of the balsa block. As you can see, my PVC tube had cracked because the wood inside had collapsed and the rotted wood was being compressed against the end of the tube. The little tube was not quite up to handling the compression load.. I saw no evidence of wet laminate under the aluminum plate from a couple of 1/4" holes I drilled to check and to gibe the epoxy something to hold to.. I sealed the tube by filling it with RTV.. since there are no loads and no movement, that should be there a long time. Mud daubers had made mud balls on the internal lines which fell into the mast base and plugged the drain holes.. I am a lot more vigilant about keeping those drains open now.
One of the forum guys did the repair from the top (don't remember who); I think it may be listed in the "Owner Mods" section. The most elegant repair, in my opinion, was done by Mr. Claude Auger on his 34. I believe Claude uploaded it into the boat section.. It is a bottom repair and installed a fine looking beam and post into the structure.. Claude sailed his boat extensively (Montreal to Bahamas and back) after that repair and saw no problems with core collapse..
But certainly do homework to please yourself.. it is your boat and your safety..
Unless you have a hose attached to an opening in the mast or a 6 inch diameter hole facing into the wind in a monsoon the volume of water will not be a worry.
I did the hose because I could give the wires a cover to the PVC and I could give the hose a soft bend in a minimal space. Remember the VHF cable has a minimum radius bend before you have problems. The LMR400 permits the smallest radius. The standard RG8 is pretty stiff and bend it to far you have transmission issues.
When you try to stuff the wires back up the mast with the drip loop and a hose they become quite crowded. All the while you have the mast suspended from a crane. It is not a place I like to play around with a lot trying to work wires through a 180 degree PVC pipe.
The below chart shows the bend radius of COAX cable. RG8 is a 2" radius. LMR400 is 1" Trying to get that to work on a PVC pipe and have any room in the mast may be an issue.
Likes: KD3PC
Nov 6, 2006
10,256
The water coming in sounds a bit much ! Does the internal wire have the correct "drip loops" so that water coming in on the wires drips off before coming inside?
OOps, JS beat me to it.. some folks have cut an service port in the mast to have access to the wiring.. and some have brought the wires out of the mast and then down through a dedicated sealed junction box to stop the leakage.. again, a search of the archives can get ya some pictures and stuff..
Hunter 34 Alameda CA
That squiggly flex hose on your wires was different than what I had. It seems that it would be a path for water to flow right down the wires and into the standpipe. I'd be inclined to remove it. Mine just has the individual wires or cables that went into the pipe directly. Since I replaced all my wiring I had lots of length to work with. So I fed my wires inside while they lowered the mast until it was about 1 foot from touchdown. That's when I squirted about 1/2 tube of clear silicone into the top of the pipe. That glob sealed everything so no cap was used. Then they lowered the mast and that excess wire formed the drip loop external to the PVC pipe. Water that runs down the wires goes below the opening of the PVC and drips off. The water gets in at the very top of the mast via the slots for sheaves, etc. You can't do much about that.
I was comfortable with sealing the PVC pipe in the hole. It was a pretty tight fit (I may have upsized to 1" PVC) and I chamfered the hole with a file first. A liberal coat of 4200 on the pipe acts as a lubricant to push it in and the fillet seals nicely around the chamfer. Its never leaked, so you should probably be comfortable with that. You may be on to something with that membrane seal though. How about a shifter boot for a car?
One thing you might consider is to add some additional drainage to your mast step. Drill a couple of 1/8" holes (on on each side) right at the top of the plate crossways into the interior of the step. That way if the weep hole gets crudded up, it won't fill anymore than the thickness of the plate.
With the pipe sealed this way, you should not have to worry about water entering. After you put your pipe in place you could cap it and hit it with the hose to see if it leaks. This is before you button up the inside and reinstall the mast.
Oct 20, 2016
56
Hunter 31 Seattle
I like the idea of a thermoplastic roofing boot, but I think there's nothing that small. Another idea I had was a QuickFlash boot cut down to size. It's really just a second layer of protection so I'm not 100% relying on that sealant around the PVC pipe. I like the idea of a pourable sealant after wires are fed in. I could simply have a slit in the side of the PVC pipe, so as they feed the wires through it's easy to get in, then push the wires into the slit, pour in some sealant, and cap the pipe. With clear drain holes and a totally sealed pipe, this is a permanent solution. Whatever was there before was horrible. They apparently had no issue removing the old PVC pipe, as I don't see any residue from old sealant like I would expect.
I already talked to the yard about the step, they said they would enlarge the weep channel. It might be good to add another channel or two on the sides. I can't believe the original design of the boat relied on a single weep of about 1/8" to let water out of the mast. Doesn't seem like it would take much to clog that up. Seems like a good design would have weeps in the step and mast, and at least two weeps on each.
Drainage was fine for decades with this boat, the leak seems to be recent. If someone hadn't sealed up the weep channel and blocked it with the spinnaker chock, it would be fine. Since a rigger drilled a hole in the back of the mast, that has kept water from coming into the tube. There may be some drips, but it's so minimal now, there's no standing water in the shower pan.
Oct 20, 2016
56
Hunter 31 Seattle
Like a house, the ceiling joists don't support the roof
Sorry, that's not true. The joists ABSOLUTELY support the roof! I'm a structural engineer. I don't know boats and how things are designed to transfer loads, so I can't comment on that. I'd need to know the compressive strength of the core materials and the maximum force from the mast to know how much area you need to spread out the load. Once you start cutting into the fiberglass beam below to get a large piece of material in there, it might need to be repaired. Again, I don't know how forces are designed to move through the boat, I'd need to ask a naval architect.
That's kinda why I'm so skeptical of these approaches that change bearing area without really thinking it through. If the old wood beam is 18" wide, most likely somebody figured out you need that much area to distribute load over the deck. If that wood beam is only needed as a shim between the compression post and deck, it seems they would've simply used a smaller piece of wood instead of wasting material. Something tells me a lot of these repairs with small bearing area are possibly near the crushing strength of the material above...
My suggestion about a boat design forum came from some questions I poised on this forum. They may provide some additional technical detail you seek.
http://www.boatdesign.net/forums/
Are you sure its not the Rafters that support the roof?
Jun 6, 2006
6,990
The cabin top beams (rafter and joist are specific engineering terms BTW) do take loads on a boat. A house rafter is part of an A-frame with the rafter taking a tension load to keep the roof members from sliding apart from the roof loads. A cabin top beam acts like a true beam supporting the mast through moments and shear. Bottom is in tension and top is in compression due to the mast weight and shroud tensions.
Oct 20, 2016
56
Hunter 31 Seattle
Bill, if that's true, I think the hollow fiberglass beam would need to be repaired after replacement material is installed so you have that tensile strength on the bottom of the beam. Has anyone done a calculation on the compressive strength of that foam core material above, to be sure that installing a smaller aluminum shim works? I'd like to know what the material is. Fiberglass has extremely high compressive strength of about 20,000 psi, rigid foams are around 25 psi (assuming polyiso or XPS, but I don't know what the material is), and douglas fir perpendicular to grain is around 700 psi, dry.
I'm seeing some repairs where people go with a 4"x4" shim, and some people are installing a wider aluminum shim, maybe 12" wide. It seems like if the shim only needed to be 4" in the first place, Hunter would've just installed a 4" shim. Based on the size of the aluminum plate and length of that wood, it seems that they determined you really need to spread the load out to avoid damage to the core material. Maybe it works with less, but you could be seriously cutting down on your safety factor with a small shim. Also with the cut fiberglass beam, this could seriously reduce it's strength if not repaired, but I'm sure there is some load transfer so that's why it may look ok.
Without having more information, I'd feel most comfortable going back in kind. That would mean installing a member the same length as that original wood to spread out the load onto the foam above, then repairing the fiberglass beam completely, and having the compression post bear on the underside of the beam.
If I did an underside repair, I'd have to pay the yard to repair the fiberglass beam below, and also to repair the damage to the fiberglass above from where the spinnaker chock was removed. The cost to do this could rival doing a 100% topside repair, where they basically gut it down to the fiberglass beam, and fill the entire area solid with fiberglass. Either way, I'm not getting out of this for less than a couple thousand dollars.
Oct 20, 2016
56
Hunter 31 Seattle
I gave the boatyard a call this morning, and they said my issue isn't the wood crushing in the hollow beam, but instead it's delamination and crushing of the layers just under the aluminum plate. They said they did some investigation, and they don't see any damage to the hollow fiberglass beam, compression post, or horizontal wood member.
I'm going to have a meeting with them again and do a bit more looking from the top and underside to see what they're thinking. If the issue really is delamination of the layers just below the aluminum plate, I think a topside repair is required, and this isn't something I'd want to do since it's all fiberglass work. He suspects that the layers just below the aluminum plate are not as non-porous as other people have suggested.
I'll definitely keep looking into this issue, and I'll likely give other yards and surveyors a call to see their thoughts on this. I'd hate to have them reseal the mast step and drop the boat in the water, just to find later that the layers just under the aluminum plate are the real issue. Then I'd have to haul out and demolish everything from the topside anyway.
