1987 Catalina 30 Wing Keel Bolts Location?
May 24, 2004
7,226
CC 30 South Florida
The keel bolts will be somewhere under the floor boards near the bilge at the hull keel joint. The wing keel is usually a unitary fixture with the wing permanently attached to the rest of the keel.
Ward H
Nov 7, 2011
3,842
Correct. The keel bolts are under the bilge cover in the center of the cabin.
May 7, 2011
281
C - 30 # 3573 Lake NormanNC formerly Bflo NY
Are you looking for some specific info on the keel bolts/nuts? Note that the aftmost nut is squarely underneath the engine oil pan. The other 5 are accessible.
