My first time up the mast a couple weeks ago and I noticed a weld on both sides of the mast that runs from the mast head down about four feet before turning forward. The weld looks to be done at the factory as it is ground down smooth with the surrounding surface. I have attached two pictures, one with a black line drawn over it where the weld is. My question....is this factory or has my boat had a run in with a low bridge? Thank you in advance
