1985 Hunter 31 New Hatches and fixed side windows :)
Dec 16, 2006
10
Hunter 31 St Paul, MN
So far, I have shiny new Bowmar bow and center hatches installed for my 31 ordered here on the site. Both fit after 30 minutes with a file on the openings which were hand cut on the boat and bit irregular. On my floor I have new plastic fixed side windows, which go in soon :) These were a bit of a dust-up as Hunter had three different fixed side window designs in the 31, from 1984-1987. Mine are the all plastic, with the integral plastic frames. There is great worry to get the right ones. Note: If you ever take a side window out, measure the thickness of the opening cut out every 8 inches as that sometimes varies and is needed for the window people. And measure and photograph the insides, outsides, etc. of the window.
pateco
Aug 12, 2014
2,207
Photos Please.
Mine were the Aluminum frames. which I stripped & polished and then re-bed the plexiglass panes.
I need to redo the starboard one as I did not use enough butyl tape when mounting it and it has a slight leak.
Mar 20, 2011
624
Hunter 31_83-87 New Orleans
Kloudie, did similar replacement about a year ago on plastic frames. Mark Plastics in Ca still has the molds and info for mid 80s Hunters. You can Google that company for contact details. I tried repairing mine with new lexan and it still leaked so decided to replace with new frames, etc.
