So I just picked up this 1985 Catalina 30 with a Universal Diesel M-25 engine. The heat exchanger and the exhaust pipe, prior to the wet muffler, were both leaking sea water all over the engine. After cleaning it up a bit and unsticking the throttle cable we got it fired up, then noticed the leaks mentioned above. The Transmission cable was stuck just like the throttle cable, we disconnected it from the transmission and with some lube got it moving again, but the shifter arm (on the transmission) won't move when the engine is off.
So my question is, does the motor need to be running in in order to shift into forward and reverse?
I'm scared to test this as I'm in a marina and don't want to get the trans stuck in one position.
Thank you!
Thank you!
