1984 Hunter 31 large windows
Hunter 31_83-87 Philadelphia PA
I need new large windows on my 1984 Hunter 31. Opening ports are OK at this time
Any help would be greatly appreciated
Thanks
Dec 2, 1999
15,184
Just get some acrylic and replace what you currently have. Use DOW795 to seal them in place. You can put srews holes in place to hold the ports in place until the sealant cures. Once it has cured you can fill the screw holes with caulking.
If you drill scew holes be sure to use t tapered plastics drill to prevent edge cracking. Better yet have the shop that sell the material drill them for you.
Hunter 34 Alameda CA
Did you put a piece of trim over the new window? I have the plastic and it's pretty shot. I know I won't be able to salvage one side, the other will be iffy.
Thanks much.
Almost missed this one. My trim was shot so I did without. The silicone adhesive makes the finished window look nice.
