1984 Hunter 25.5 mast wiring
Nov 26, 2012
1,654
C&C 40-2 Berkeley
It runs through a channel un the compression post to the base and the then laterally to the side of the boat
Nov 26, 2012
1,654
C&C 40-2 Berkeley
If you were to remove the compression post which is that teak veneered 2 x 4 right there in the top photo attached to the bulkhead you would see that the back side of it has a channel that runs top to bottom. The mast wiring runs through it. I replaced the compression post on mine a few years ago so I had to cut the channel in it for the wiring.
SeanTX
Jul 23, 2016
32
Hunter 25.5 Canyon Lake
Thanks! Going to be a project I see!! Need to go up and replace mast head light.
Nov 26, 2012
1,654
C&C 40-2 Berkeley
Well, I probably don't have to say this but don't remove that compression post without first stepping the mast or, at least, supporting it in some way.
Likes: SeanTX
Sean,
What drives the light replacement. No Light, Change of bulb, wiring issue?
Our boats are different, but the electrical issues are similar.
  1. Contact corrosion. Clean contacts, spray with a corrosion block or dielectric grease.
  2. Bulb burned out. Replace with new bulb and check for corrosion.
  3. Wire connections. Remove the end of the wire (usually an inch or so). Strip wire and reinstall a good connection. I like heat shrink adhesive ring connectors. Check out MaineSail's website filled with great electrical/boat info (http://www.pbase.com/mainecruising/boat_projects)
  4. I suspect (unless previous owner changed them) the wires in your mast have connectors that come apart above the deck inside the mast. Lifting the mast will expose these and you can unplug the mast wires from the boat. No need really to go inside the mast compression post unless you have to.
  5. Check for continuity. A good meter is an essential tool for boat electrical work. When without hook up a battery and light. Serves the same purpose.
Good luck
SeanTX
Jul 23, 2016
32
Someone got wires tangled in mast when it was unstepped is my guess. I guess this big fat ground wire is for lightening strikes? I had closer look at so called 2x4. Looks like back side may come off. Plug on mast seems to be intact. It is 4 prong and only 2 are being used 4 wires going to it and there are 2 wires going to 2 prongs. So that must be wrong. One should go to mast and one should go to masthead cuz it is a running light.
Pretty ugly!! :(
