1984 H34 compression post again
Aug 6, 2016
9
1983 Hunter 34 Pensacola
I am sure everyone knows about the Compression post problem on some Hunters where the wires went down the wood post from a hole in deck plate that the mast is secured. Here is a picture of the post removed on my project boat. I can not believe that nothing held the wood post on except the pressure of the top deck and floor compressed by the rigging. Anyone with a boat like this needs to check the post before sailing off on a nice windy day.
Nov 6, 2006
10,253
The bulkhead and wood door trim for the head keep it in place if unloaded.
EDIT but only when there is wood in the post, as original.
Likes: Allan12210
Jul 28, 2013
126
Hunter 34 Holland, Mi
I did mine a few years back. I used stainless pipe with plates on each end to fit the original space on the upper and lower points.
Jul 28, 2013
126
I also made the wiring accessible by making the side removable. The previous owner didn't notice the issue so I had to remove some of the plywood wall to get rid of the rotten material.
