I recently replaced my M25 alternator mounting bracket from the original to the universal modification. In the process all the wiring from the alternator got broken. I have it back together except for one wire off the alternator. I have the original 1984 alternator with the voltage regulator attached to the backside of the the alternator and clearly visible. There is a thin yellow wire coming out of the regulator which I believe is the voltage sensing wire. The wiring diagram for the M25 manual shows a wire coming off the alternator and attached to a purple wire on the wiring block next to the engine. It seems obvious that these should be connected as I have the yellow off the regulator and a loose purple on the wiring block. Without the wires connected and the engine running I am showing very close to 15 volts on the voltmeter at the starting panel which I think is the max factory setting for the alternator and an obvious overcharging condition for the batteries as it does not move down. I am hoping a C-30 owner of either a 84' or 85' with the original motorola alternator can verify that these yellow and purple wires should be connected...Thanks for any help Wayne owner of Steadfast hull #3701
