rudder bearing plate
i had a '96 36 mkII. a friend had the same year and model. what i am going to tell you happened on both boats. the upper rudder bearing support plate broke free and caused the boat to leak at the bottom due to unsupported movement. upon inspection, i found the plate to be only 3/16 thick with a span of about 3 square feet. the plate was only glued to the frame, not laminated with cloth and resin! in addition, upon pulling the boat to repair it, i discovered the rudder to be misaligned with the keel by over 5 degrees. the reason i missed this in the survey, was because the boat was pulled from the slip with the rudder too close to the water to back up and look at it. catalina offered to pay $300 to fix it. i declined the offer. my neighbor took the fix. they smeared caulking on the inside of the boat to stop the leak and re-glued the plate. the plate will surely break again as they still did not laminate with cloth. (this would have been an admission of poor design). the caulk on the inside will allow water to come in through the outside and deteriorate the laminate at the most important place in the hull. after $7,000 at my own expense, my boat was repaired correctly except for the rudder misalignment. i am a degreed mechanical engineer with 30 years experience with sailboats. i have probably owned 15 or more boats. i have never dealt with a company as crappy as catalina when it comes to admitting an error and paying to fix it. this does not negate the fact that they have made a lot of really good boats. i hope yours is one of them.sincerely,robert taylor
