1982 H27 wire size standing rigging
13
Hunter 1982 H27 Lake Oologah
I am rigging a 27 foot 1982 Cherubini, and currently does not have the rigging, I need to know what wire size fore/aft/ spreaders etc. any info pictues etc would be greatly appreciated. thanks (John)
Jun 14, 2010
13
Thanks David, just trying to figure what size wire to buy. Then I will have to loft the mast, figure out where the spreader goes. Then get fittings swagged. BTW nice to see your from Ohio, I'm originally from Youngstown prior to Navy career.
John
Dec 2, 1999
15,184
John:
Contact Seco South, Fl. regarding rigging. It is cheaper to have them make it up for you than purchasing the pieces. I believe that they have all your specs.
Jun 5, 2010
1,136
Hunter 25 Burlington NJ
I'll go with Steve or David on this. You could ask at Rigging Only or Oyster Bay as well. My H25 is upgraded to 5/32" and I'd have assumed that'd be adequate for the H27. I will say that originally my forestay and backstay were bigger than the lower shrouds, like 1/8" vs 3/32" (?). But I've upgraded a lot on this boat.
Jun 14, 2010
13
I don't want to sound totally clueless, but its pretty much a bare mast, no spreaders at the mid point up the mast and I've seen many pictures they are all air foil type mounted on the sides of the mast. My mast has no holes on the sides of the mast any where near the mid point however there is a welded round pipe approx. 1 1/8" OD just below the running light on the mast at about halfway up the mast on the fore side of the mast.
