1982 Cherubini w 12 HP Yanmar - Hull Speed?
Thanks man. Id need to validate but cant find a recommendation.
Mechanic tells me 14x12
Chat tells me safer to go with 14x10
Do you happen to have the the formulas or calculatior to right size / pitch propeller?
Yanmar 2GM 13hp with KM2-A 2.62 ratio in a hunter 31 1984.
thanks!
If by chat you meant chatGPT, this doesn’t feel to me like the kind of question chatGPT is especially well suited for. If you work with a prop manufacturer they’ll be able to tell you the right pitch based on engine and transmission specs. The right numbers could vary based on prop design - a Michigan wheel style prop will have different numbers from a Campbell Sailor Prop, and different again from feathering and folding props.
thanks!
There are a number of variables that go in sizing a propeller, engine HP, RPM, Torque, hull clearance, prop design, blade count, and hull design to name a few. Incorrectly sized props can impair performance and potentially damage the engine. A prop manufacturer or a shop that specializes in props and drive train parts will provide the best answer to your question.
Michigan Wheel and Campbell Sailor are well respected propeller manufacturers. Contact them for advice on prop sizing.
Isskra
May 26, 2026
5
Hunter Cherubini Erie
I'm not certain of the speed. But the boat will only go the hull speed capable of the hull. It's important to remember that thrust is important at times, like leaving or approaching a dock. My hunter cherubini 27 has a Yanmar 8.
Hull Speed is not a speed limit. It is an efficiency rating based on the wave length of your wake. As a hull moves through the water, it creates a series of waves. The faster the hull moves, the longer the wave length of the wake. Once the hull's speed is such that the wave length is longer than the waterline length, the hull is effectively trying to drive up the bow wake. The motor or sail, is pushing uphill against water resistance and gravity. That is the point at which power to speed begins to really fall off.
You can certainly get a boat to go faster than Hull Speed, but it takes more and more power until you've added enough power to drive the boat to the top of the bow wake. Then, you're planing, and the energy to speed curve plunges back down again. That is, unless the hull design drives the boat under the bow wake, then you slow right down to the bottom. :facepalm:
-Will
Isskra
May 26, 2026
5
-Will
Maybe I didn't put enough time into my reply. I'm basically saying that the hull speed is all that you should typically attempt to achieve efficiently. An engine with more h.p. will, however, provide better thrust at dock.
181
Hunter 33 Danversport, MA
I have this boat as well. It has the 2 GM 14 HP 12-16 HP depending on where you read.
This set up works well. I can tell you that the Propeller choice will make a Significant
difference in the available power.
After a lot of homework, I got Michigan Wheel to do the propeller math for me and it is like someone
bolted on a turbocharger. I got their three bladed sailor model..
It went from barely making 4.75 KTS to 6.5+ KTS.
The motor is bulletproof.Simple to work on.
My biggest complaint about it is I can't make Hot water with it. That's is.
Jan 19, 2026
8
Hunter 31º Watergate
What size and pitch?
I got West by North Industries proposal for a 13x8.5,
Yanmar 2GM 13hp with KM2-A 2.62 ratio in a hunter 31 1984 propeller size and pitch.
Found an ebay one 14x8 for cheap -> Im giving it a try - will update.
I took the boat for a tour with current prop, and I could get to aprox 2200 rpm, but just engaging fw was enough for close to 5kts at 1200/1400rpm so I dont have much control atm.
Sep 27, 2008
181
This worked A+++++ for me. Give it a try
  • Helpful
