1981 Hunter 33 Rudder Replacement
252
Hunter 41 Longport,NJ
Just heard from the mechanic - Rudder shaft is bent and the entire thing needs to be removed, fixed and re-fitted - cost is 3500-4500 - that's about 1/4-1/3 the value of this old boat - does that sound reasonable ? Is there a source of reconditioned or salvaged rudders to make more sense ?
skfnek
Aug 20, 2007
1
- - Galveston, TX
I'm in the process of replacing the rudder on my H28.5. I ordered a replacement from Foss Rudders (google it). Since my boat is on the hard for bottom paint anyway, I arranged with the yard to drop the old rudder myself which took about 2 hours. I measured the old one to ensure the replacement will be an exact copy. Al @ Foss has been very helpful. This all costs less than half of that $3500 you were quoted. I'll bet there is a website for your 33 that can give you the details of unhooking your steering quadrant, then you reverse the order on the installation of the new one.
