1981 Hunter 27
-na -NA Anywhere USA
I am beginning to fix a 1981 Hunter 81 for the Boy Scouts on a volunteer basis.
1. What is the specific model of the Yanmar engine. Is it a 9 hp or a little lesser.
2. Where can I get a single stanchion for this boat.
When I retired, I figured why not use my God given talents and I am enjoying working on a volunteer basis on daysailor fleets for the Boy Scouts. Even the exerience sometimes need some help like in this case. Thank guys.
Crazy Dave Condon
Formerly of American Marine & Sail Supply
Yes I can still be squirely
Jun 2, 2004
5,802
Hunter 27s had different motors over time. By '81 I think it was the Yanmar 1GM10. Who knows how many horses are still in there? Two sources of stanchions that we hear about are Garhauer and White Water Marine( http://www.whitewatermarineinc.com/ ).
Nov 8, 2007
1,620
SB 8?
My '77 model was an SB 8, rated at 8 HP new, and probably producing 6 HP when I replaced it.
MrUnix
Mar 24, 2010
626
Hunter 23 Gainesville, FL
Same here.. my '77 H27 had a yanmar SB8 (8HP) in it when purchased.
Cheers,
Brad
n624ma
Jan 27, 2007
48
Hunter 33_77-83 Groton Ct
Dave, Can you post a picture of the stanchion you need (particularly the base)?
May 24, 2004
7,237
CC 30 South Florida
During that time the h27 was equiped with a Renault engine or the the 1GM Yanmar rated at 6.5HP. Depending on how horsepower was measured this same engine was advertised as producing 8HP. It is a strong little diesel engine producing a large amount of torque able to drive a fair sized propeller.
Dec 27, 2004
139
Hunter 340 Burlington, Ontario, Canada
The 81 h27 that we had (since moved up to a 340) had a Yanmar 1GMH which produced 7.5 hp. Reliable but single cylinder so a little noisy. Guaranteed to wake the marina if leaving early in the morning ;-). I changed the engine mounts (suspect they were original) and made a world of difference. Be sure and check the cutlass bearing, shaft and engine alignment too. This was my project boat so happy to answer any questions! Scott
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
My 1980 has a renault RC8D 8hp single cylinder, screw loosening, filling extracting thumper on board.
You may want to reach out to Jorge on this site, he's got a line on a boat junkyard where he may be able to source a stanchion for you.
Thanks,
Thanks to all and the engine was a Yanmar 1GM 8 for 7.5 hp. Now for the stanchion.
I can take a picture but would prefer to know who could replace it. I think the base is the issue but the one looks ok. The boat is 4 hours away and it will be next month before I am back on it to take a photo. Thank you for your help.
crazy dave
