Hello,
Can anyone tell me if the rudder must come off to remove the skeg on 1981 H30? I have removed (5) 6" stainless lag bolts but the skeg doesn't drop. Normally when things like this occur I suspect that I missed a bolt. If that is the case here, it is at the lowest point under (epoxy?). I would like to remove the skeg for repair (hopefully without pulling the rudder).
Also wondering why the skeg is not glassed to the hull? Would it be detrimental to glass the skeg to the hull? Looks like old repairs using 5200 or some type of sealant.
