1981 H27 Shoal Draft - How Much Bottom Paint?
451
1981 Cherubini Hunter 27 Shipwright Harbor Marina, MD
Does any one know how many gallons of bottom paint I should get for my 3'3" draft H27? Gotta paint it and thought it would be good to make sure I have it in hand before I start.
Thanks in advance for the help.
thaeni
Sep 28, 2008
120
Hunter 33.5 Chicago
I have a 1984 27' and applied 2 coats of Vivid. It took just about 1 gallon.
Jan 24, 2009
451
Thanks for the quick reply, thaeni, that's a big help.
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
My 1980 shoal draft takes a gallon for two coats if i'm carefull - I use the hard epoxy stuff.
Manny
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
Most bottom paints will cover 400 sq ft/gal. A basic rule of thumb to figure out how many square feet you need to cover in one coat is: lwl x max beam x .85.
