1980 Hunter 30 Prop Shaft Diameter?
Jan 30, 2021
14
Hunter 30 Cooper River Marina
I forgot to measure this before I drove home and I need to order a parts kit for PSS shaft seal and don’t know the shaft diameter. Anyone know this? I assume it’s standard size on this particular model.
May 27, 2004
2,059
My '79 is 1 inch as well.
Please let us know the details of your install.
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
Did you measure the shaft log? You'll need that too.
Jul 7, 2004
8,542
currently pulling the shaft on my H27,, stuck at the coupler,,,,just won't come off,,YET,,,,lots of wear and grooves in the area of the cutlass bearing,,,what I can see of what is exposed now,,,photos later,,,,not liking this,,,has to be a used shaft in a boatbone yard somewhere,$480 is not in my budget,,,
I see hunter sells the coupler with it too, well the shaft is shot at the bearing, so I could cut it, and have the couple pressed off??
If it were me: cut the shaft and get a new coupler and shaft. I went back with a split coupler. The next owner will have it easier than I did.
  • Ha
Likes: Brokenarm
