1980 h37c hot water heater install
Jaxg
Jun 30, 2019
18
Hunter 37 Cherubini Jacksonville
Where in the heck can I squeeze this thing in? The starboard lazaret os the only place that seems large enough to hold the 6gal unit. However with hot water heater on my breaker board I’d think that there is electrical sitting somewhere close to plumbing made for the install. I just can’t seem to find any schematics to help answer the questions about wiring and plumbing.
May 27, 2004
1,312
In an earlier year (1984), the water heater was located just forward of the helm, under the deck.
Likes: Jaxg
C&C Frigate 36 St. Margaret's Bay, Nova Scoti
The stock location was under the cockpit sole, aft of the engine. If you look in that space, you will find a sort of shelf just above where the shaft log exits the hull. Remove the partition between the engine compartment and the starboard cockpit locker to get the heater in place. 6 gal, square or round fits in there.
Likes: Jaxg
Jaxg
Jun 30, 2019
18
You guys are awesome thanks fo much for the help!!! If you ever need a warm shower I’m here for you!! Loll
