Hey Jed
Jed, This may seem a bit convoluted, but I'm the son-in-law of Bob, following his quest for the next engine. Since not much else is going on with his query so far, and as you didn't specify inboard or outboard I thought I'd throw my two cents in. The fact is the Bobalew gets around right now rather well with a Honda 15hp four cycle on a stern bracket. You may already know this, but here's my argument for an outboard. The Honda is a reliable, quiet, efficient engine, requires no fuel-oil mixture, retracts from the water, thus reducing drag and the corrosive effects of salt water. It is easy to maintain and winterize, and because it pivots it becomes a "rudder turbo charger" making the boat very maneuverable under power. Further, if fouled it can be much more readily cleared than a through-hull power plant. I know from personal experience, as I recently had to dive repeatedly on my prop (I have a 34 Morgan with a Yanmar diesel)to remove a hunk of hawser that probably was deposited by one of the countless tugs that ply the Long Island Sound. Let's see, the negatives. In serious chop the engine can get lifted right out of the water, causing it to over-rev. Bob also complains about having to reach over the transom to adjust engine speed.Acknowledged. If anyone reads this I'd love for them to take up the argument for an inboard refit, if only to help me feel smug about my Yanmar. We know it's going to cost a chunk, but how much? Is a rebuilt engine a viable alternative? What brands will go in the well? How much might a used refit cost? Where can you get them?That's all for now.Bob's SOL
