1979 Oday 25 Hull Composition
JayK
Does anybody out there have an idea if a 1979 Oday 25 is a full fiberglass hull or is it cored with wood? Also is the topside fiberglass or wood cored? Im not sure when Oday switched to using wood....
E
Ed
Hull
The hull is solid, about 1/2" thick in the bottom, the "topsides" are solid, about 3/16-1/4" thick, the deck is wood cored.
Don Evans
Some Balsa Ondeck too...
Ed is correct but I have found balsa wood on the deck wherever there is a camber or curve, the remainder is plywood. Don
