1979 Hunter 33' Jack heights & count
Jan 25, 2022
15
Hunter 33 Freeport
Hi. I'm currently thinking of purchasing a project boat to eventually call home. I'm looking to get it transported within FL and dry storing it on my property to spruce it up. But, I'm hoping someone could inform me on how many and what size sailboat jacks/stands to use?
May 27, 2004
2,059
Hello V Carter. :clap:Welcome aboard the SBO Forum.
My 1979 H30C shoal draft takes 6,
(plus one for the bow if I'm staying aboard and moving around on deck)
You might need 8, spaced around bulkheads, plus one for the bow.
First question is:
Do you have a shoal draft or deep draft keel?
My jack stand 'facing panels' are 5.5 ft. off the ground with a 6 "
solid wood block under the keel.
There are many Cherubini owners comments in the "Owner's Mods" section of the forum, and many experienced DIY boat rebuilders here as well.
So, feel free to ask whatever questions come to mind and someone will have the answer...
Or at least give you an educated, if not a SWAG, answer! :laugh:
Likes: V.Carter
Jan 7, 2011
6,017
Oday 322 East Chicago, IN
I have a few buddies with newer H33’s. Marina uses 6 (3 on each side) usually, but they (and I) usually throw on more pair under our boats ( I have an O’Day 322 ).
Plus the bow stand as @ggrizzard said.
Greg
Likes: V.Carter
Jan 25, 2022
15
Hunter 33 Freeport
First question is:
Thank you for your reply. I'm going to say it's a fixed deep draft keel at 5'3".
Jan 25, 2022
15
Hunter 33 Freeport
Greg
Thanks for the reply. That sounds about right. I've seen many images of vessels on the hard and it seems 6 is the standard. Especially if you plan to work on the vessel.
