1979 Catalina 30 Engine swap Help!!
ZTS213
Mar 31, 2015
6
Catalina 30 Port Aransas tx
Please Help! I bought a 1979 catalina 30 project without the motor.
I have a yanmar 2qm 20hp that won't fit and an atomic 4 that won't fit. I'm guessing the boat came with the universal 5411 because of the wide stringers the atomic 4 doesn't even touch, and from what I got from the original owner it had a ysm12 he pulled out. It's not the size of the motors I have that prevent them from fitting it's the fact that I can't get the Trannys to line up with the prop shaft. The prop shaft is a few inches lower than the Trannys. The output shaft is almost level with the engine mounts on my 2qm and atomic 4, is the tranny output shaft lower than the mounts on the universal 5411 or ysm12? What can I put in it that will line up?? Any info will help. Thanks Zachary.
