Sailors,
We were trying to step the mast this morning on our new C-22. We did the following:
Picked up mast, walked it aft until the base was over the mast step plate. We lifted the mast just enough to get the pin in at the bottom. Once it was pinned, we tried lifting the mast.
The problem was that we were only able to lift the mast about two feet before something started binding and prevented the mast from going up any further. It was not the stays/shrouds, so this lead me to believe that the mast was binding in the base.
Should we raise the mast to a certain degree before pinning it? Or is it ok to pin the mast straight away? Upon reflection, I wished we had jiggled the base of the mast and tried to pull it up a bit to maybe get past the binding. (But since this is out first time, I didn't want to risk breaking anything due to my huge amount of ignorance.)
Thank you kindly,
RG
Thank you kindly,
RG
