1978 - 1983 Hunter Electrical Panel Question
May 27, 2004
1,619
For Kito and those of you who have looked at or changed the panel connections of your Good Old Cherubinis or are willing to check yours to answer this question: On the DC (12 volt) rear side of the panel do you have a WHITE ground wire coming from the engine compartment, (that is attached to the engine block), that connects to the switch panel?
If so, Where is it attached on the panel?
If not, How is your panel grounded?
Second Issue:
Anyone using a Blue Sea or Paneltronics panel?
Good or Bad reviews welcome.
Thanks in advance for your help .
