1975 columbia 26t deck cleaning project
F
fletcher
just bought the boat and the deck is very dirty. can anybody suggest a cleaner and cleaner / wax that is tough enough to remove 5 years of chalk? thanx. fletch
Jun 16, 2005
476
- - long beach, CA
deck work
scrub it with hot water, Tide detergent and a stiff bristle brush. let dry. use a rubbing compound on the smooth parts, applied by machine, or by hand. hit it again with a polishing compound, then two coats of a carnuaba paste wax. on the non-skid, hit it with rubbing compound applied and removed with a stiff bristle brush to remove as much oxidation as you can, apply two coats of Aurora non-skid deck wax. unless you're totally anal and you want to go sailing instead of futzing around, that should do it.
Dirk
Power Washer
I use deck soap and a 1300 psi power washer. It's not a strong one as power washers go, so i'm not worried about screwing anything up. That should get you through the grime- what you do after that is up to you.
higgs
Aug 24, 2005
3,736
Nassau 34 Olcott, NY
Sea Bright
I had good result on my '73's non skid with Sea Bright Teflon non skid cleaner.
Sep 21, 2006
280
-Hunter 35.5 Washington, NC
Kaboom
Best all around boat cleaner I've found is Kaboom. So far I haven't found anything it won't remove, including week old red wine stains on fiberglass.
Oct 14, 2005
2,191
Fletch...
jump on the Yahoo Columbia forum for boat-specific help from a bunch of Columbia owner experts. See you there...
