Irwin 25 Specs
Hope that helpsRegards,LarryIrwin 25 Length Over All................25' 5 Length Water Line..............20' 6 Beam........................... 8' 0 Draft: Full Keel.............. 4' 0 Centerboard,Up......... 2' 8 Down....... 6' 8 Ballast: Full Keel............. 1,835 lbs Ballast: Centerboard........... 2,200 lbs Designed Displacement.......... 5,400 lbs Sail Area (Main + 100% Jib) ... 315 sq. ft. Main................ 148 sq. ft. Jib................. 156 sq. ft. Rig Dimensions: P = 27' 6 E = 11' 0 I = 31' 3 J = 10' 0 Morc Rating 19 to 19.5 Aux. Power: Outboard in transom cutout Headroom (Main Cabin) ......... 5' 9 Sleeping Capacity............... 6 Water Capacity (tank under V-berth) ...25 gals. Calculations based upon brochure data (by Cucurello) DISP/LWL....... 279.8 SA/DISP (Main + 100% Jib) 15.85 SA/DISP (Main + 150% Genoa) 19.91 Ballast/Disp Ratio: ________________Keel 33.58% ________________CB 40.74% Displacement Hull Speed 6.11 Knts. PHRF Rating 224 (from New England Web Site) Info Via Measurements Directly from Hull # 104 Rig Type: ________Sloop ________Masthead Rig ________Single Upper + Lower Shrouds ________Backstay offset to port. Standing Rigging 3/16 SS 1X19 Toggles + Turnbuckles: Bronze 3/8 pin and 3/8 screw Centerboard Cable 3/16 Stainless Wire 7X19 2 part + Phenolic Rod Halyards (Main + Jib): 1/8 wire with 5/16 Dacron Tails Spreaders: Aluminum Tubing 1 + 1/8 inch diameter: 1/8 inch thick wall @ 32 Inches Length
