1970's era running lights
rad
Does anyone know where to find replacement sockets for the Hunter 74- 80s era bow running lights. They are bi post twist lock and the socket has metal spring clip tabs to hold it into the running light frame. I will try to get a picture for a better explanation.
Tim R.
May 27, 2004
3,626
Why not call Hunter?
If they don't have the parts, they certainly should be able to tell you where they sourced them.
Paul Z
Macgregor 24 Oregon City, OR
Bulb Numbert
Here is a link to commen miniature bulb types. Find the base then you can get the number easily because you know the voltage. http://www.topbulb.com/find/miniature_bases.asp
Aug 9, 2005
772
Hunter 28.5 Palm Coast, FL
how about replacing with bright LEDs?
they don't generate heat and use a lot less power. You can even glue them in the lenses and forget about the sockets.
