I added some pics of the cracks that my H170 has I have begun grinding the edges of the transom crack to prepair it for a fix. When it stops raining for a day or two here in Jax I will check the condition of the wood under the motor mount. I have already removed the SS rudder and motor mount brackets to ensure I have a water tight transom when I finish. If anyone can offer advise on these repairs it would be much appreciated. Thanks for the replies I have gotten already!! I have researched some great ideas and conflicting opinions with regards to fixing a core backed deck but my concern is one with out a core backing on the deck next to the center rib. SEE PICs.
Thanks again and Happy Sailing. db
I recently purchased a 98 170 with a foot long crack next to the center foot rail on the deck. When I look in the crack I dont see any foam core or other support material. i.e. wood, balsa. Has any one fixed a crack like this on thier deck? I have read all the posts on this site with regards to fixing foam core backed cracks but was hoping someone had a technique for fixing the deck that does not have this foam core. Thanks for any advise you can provide.
Happy sailing,
DB
Happy sailing,
DB
