P
Pat
I'm in the middle of buying a new 260 and was told by the baotyard that they had talked to Hunter and adding a 150 roller on the 260 is not recommended since the sail would have to run outside the shrouds. They say this will cause a problem with sail trim when I try to go close hauled. I know the sails are available for the boat so I was curious if anyone has added winches aft to get around the angle problem on the standard winches? Any help would be great!
