150 Genoa
Pat
I'm in the middle of buying a new 260 and was told by the baotyard that they had talked to Hunter and adding a 150 roller on the 260 is not recommended since the sail would have to run outside the shrouds. They say this will cause a problem with sail trim when I try to go close hauled. I know the sails are available for the boat so I was curious if anyone has added winches aft to get around the angle problem on the standard winches? Any help would be great!
David Foster
Asymetric Spinnaker for light winds
See the sail loft on this site. It's a much better light air solution. A 150 genny is a racing rule beater. David Lady Lillie
