14" prop on an H33?
298
'79 Hunter 33' HUN33190M79L Olympia
Hi. Apparently I need a new prop. So says the diver who scraped the bottom of my H33.
Anyway, the Yanmar 2QM15 manual says that 14X10 is the max for a three blade prop. The way the motor runs so cool, it seems the max would be the way to go, but does anyone know if a 14" prop will fit on the H33? Do any of you run a 14X10 with the 2QM15 with your H33?
Dec 2, 1999
15,184
I would suggest that you take your information from a Prop Specialist. It depends on the type of prop you want (fixed, feathering, folding) and do you want two or three bladed.
Do you have a budget for a new prop. The cheapest is a used two bladed for about $80-120.
You may want to contact these guys and see if they have some suggestions for you too.
http://www.westbynorth.com/
5,802
The original diameter on my H37C with the 2QM20 was 15". I don't think the clearances back there are much different between our boats. So a 14" diameter should be fine. But as Steve points out the pitch is everything and depends upon the kind of prop.
Feb 17, 2004
268
Hunter 30_74-83 Lower Salford, PA / Tolchester,MD marina
if you are interested in a 14 x 11 x1" left hand
send me an e-mail
Ian McGain
s/v Meant to Be
298
Got that info and prop already
As I said in the OP, the Yanmar manual has the dimensions and pitch recommendation, which is 14X10 max. The last prop specialist I called (Tacoma Propellor) didn't seem to know about the specific boat and went off a chart with HP and RPMs. They recommended similarly. I purchased a 3 blade 14" prop off ebay recently for $80. 2 days ago I was standing on the dock, looking at the prop and the clearance seemed very tight, so I figured I'd ask you guys
Jun 3, 2004
298
Thank you
Thank you for all the information. It still occurs to me that I could bypass all of it if there were an H33 owner with a 14" or larger prop working well on their boat. What am I missing? Are there many H33 owners in this forum? Do any of you know your prop size?
Jun 5, 2005
5
- - Alameda
In 2003 had yard put on RH 3-Blade Prop everything work just fine tom
