Noticed the other day that cockpit water is draining into the hull and not out the back. The hose has disconnected. Does anyone know how to fix this? Thanks.
Yes, Have a look at the article (Photo # 8) I published in the H15 section of the Hunters Owners Modifications ( http://hunter.sailboatowners.com/index.php?option=com_kb&Itemid=267&cat_id=1056&aid=8024&page=article&mn=15 ). That will show you what it looks like. Access is via the inspection port at the stern. You will have to do it by feel. Suggest you stick a digital camera in there and take a photo to see what has happened. Most likely the plastic clip that holds the retic hose onto the cockpit drain elbow has come loose and the hose has disconnected from the elbow. Hope you are good at working by touch blindfolded.
