12vdc power to ray marine course computer st60????
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
ok after reading the manual from ray marine i still dont have a clue what size conductors , breakers and fuses to use to power this up ...the chart they have is very confusing so i am at the mercy of my SBO techs ...what are the sizes i need to do this it is only a 5 ft run round trip ...also i have a grounding wire lug to connect to the battery/buss and am using #10 wire for this...is that correct or do i not use it ....its a wheel pilot 60st system.....thanks in advance for the reply's....
regards
woody
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
A 12 gauge stranded wire should be plenty for the wheel pilot.
Lee
thanks Lee...would I use a 20 amp breaker on that set up.... the manual is all over the board with there info...it also has a extra ground wire that is to be installed to the battery ground/buss ground ...i guess that is to ground the whole controller to bat ground......
regards
woody
Oct 17, 2011
2,809
Ericson 29 Southport..
Woody, all said is true. Yes you need that separate #10 for the case ground, and 12 will run it. A twenty amp breaker is a little large I would think. Five will pull it, but a ten would be better. Essentially it is just protecting your wire run, the computer is fused inside.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
thanks Chris and Lee....
then #14 wire will feed it if 10 amp breaker will protect it ...again thanks
regards
woody
