I rebuilt my YSM-8 a few years ago and bypassed the mechanical lift pump in the process when I found the pump's membrane was ripped. I installed a 4psi 12v pump that runs when the key is on and makes bleeding is a snap! The pump lasted for a few years and finally bit the dust this winter, so I replaced it with the same model. The engine ran at the dock yesterday (predominantly at idle) for about a half hour to top-off my batteries. When I secured the engine, I checked the pump on a whim--it was quite hot to the touch! I'm ashamed to admit that I never checked the temperature of the previous pump during operation, but it is likely that it got as hot. Should I be concerned? The pump (both times off eBay and from two separate vendors) was supposedly diesel-capable, but is it working too hard to push what little fuel I use? Finally, would it be in my best interest to find a lower PSI pump (pass-through capable) installed on a switch for bleeding and get a replacement mechanical pump to put back in the fuel system for normal operation? Thanks for any help!
