P
Pat Spino
Let's forget about the "Perfect World" of battery power. We will be cruising the Chesapeake/L.I. Sound areas over the next several years, with a POSSIBLE trip "down south" to Florida. I currently have between 300-350 amp hours in 3 batteries (NOT INCLUDING the starting battery!). My altinator is the stock 70 or so watt output that came standard with the Legend 35.5. We plan to anchor out as much as we can. On the other hand, I'm not going to the Carribean where you would anchor for long periods of time and need a higher degree of self-sufficiency. In our situation, we would always be within easy access to a marina facility. IT SEEMS TO ME(!) that a wind generator is overkill for the kind of cruising I will be doing. I have found on previous 3 to 4 week cruises to Block, Mystic, etc., with a smaller boat and about 200 amp hours available, we were fine with just battery and engine power. I would turn the refrig. thermostat to a low setting, or completely off at night, and use block ice to supplement the 12 volt power. Do any of you feel that a flexable Solar Panel would be of any help, keeping in mind that my house bank batteries are wired together? Any suggestions/recommendations from those of you who have done, or are doing, what we plan over the next few years will be appreciated. Thanks to all in advance,Pat
