I just bought an edgestar brand AC/DC compressor based fridge/freezer. While it is not as nice as the Engle in features it is quite a bit cheaper. It does have removable wire racks so you can load them up in the house and just carry the racks to the fridge.
http://www.compactappliance.com/FP6...le-Refrigerator-Freezer/FP630,default,pd.html
It is 110V / 12/24V and has priority on the 110v source. So if you plug both in it will use the 110V if both are available. It draws about 2.5 amps when it runs on dc and so far in the winter is does not run very often at all.
We have the same one as in the link above and love it.
http://purplesagetradingpost.com/sumner/macgregor2/inside-22.html
So far we have only used it 25 days on our Florida last fall, but will be using it again in a couple weeks. I have an amp meter that ihttp://purplesagetradingpost.com/sumner/macgregor2/inside-22.htmls accurate to .1 of an amp and when it runs I see about 3.5 amps of draw. It didn't run that much last fall as it was go cold and often we turned it off at night and it would maybe go from 38-40 the night before to 44-45 in the morning when we would turn it back on.
We have 180 watts of solar and in 25 days, besides what we ran the outboard, we only had to run...
... the gen-set .....
http://purplesagetradingpost.com/sumner/macgregor/outside-13.html
....about 1 1/2 hours in the 25 days.
I think about an 80 watt panel would handle it day after day as long as you get sun most of the time and the days aren't real short like when we were there in Nov./Dec.. We also ran the computer a lot and the chartplotter and my CPAP machine each night on those 180 watts of solar.
The EdgeStar will run in freezer mode also down to I think -8 degrees, but isn't setup to be cooler/freezer at the same time. I looked at the other two major brands, but our 63 quart was on sale for $438 with free shipping and too good a deal to pass up. We are very satisfied with it,
Sum
Our Trips to Lake Powell, UT - Kootenay Lake, Canada - Priest Lake, ID
Our Mac Pages
Mac Links
