It's on the stbd side of cockpit close to the wheel under the plastic cover. You should see the cover and the bolt heads. The handle is "usually" clipped in the stbd lazarette. If you have to replace or service it, you have to go in from the aft locker in the quarter berth and over the little bulkhead. (1979) It's a little challenging on the back but can be done.
