GPS speed II
GPS is the best thing available for over the ground speed determinations. An easy test for building confidence:With your favorite 12 channel hand held gps receiver on and locked in with velocity showing and placed on the dash of an automobile, accelerate onto a level limited access highway having mile post markers. As the car accelerates, compare speed readings with the speedometer. (It will lag little or none, indicating that the averaging time for the gps is on the order of seconds, not minutes). Now with the speed on the gps held at 60 mph (one mile per minute) start a stopwatch or simply have a passenger note the second hand of a watch as the first mile post comes exactly abreast. Keep the speed at 60.0 mph as closely as possible on the gps and note the split time or second hand position each time a new mile post marker comes abreast. This will soon get monotonous, for the mile marker always draws abreast at the 60 second interval. The test will also provide a quick determination of the speedometer error, awfully helpful in preventing speeding tickets.Velocity determination exactly the same when the gps is on a boat so confidence in velocity output with it or a similar instrument sitting on a boat exactly the same. A knotmeter, on the other hand assigns a distance for each revolution of the impeller and then digitally displays a velocity using a computed relation between distance and time, (a gps does this too) A fundamental difference though is that whereas the gps determines the necessary distance component through the arcane and accurate computations within the black box, the distance assigned to an impeller revolution is subject to error, e.g. from differences in water flow around the impeller on different boats, differences in the constant for different boat speeds, and changes in the constant coming from crud on the impeller or changes in the impeller bearing. Thus for any kind of accuracy on a knotmeter, it must be periodically calibrated. The gps can serve well for this calibration since the knotmeter calibration probably calls for running an accurate distance and then changing the knotmeter trip reading to agree with the accurate distance. Criticism of the gps velocity measurement, most especially in light of the normally used alternatives is puzzling. Tradition dies hard I suppose. At any rate, the knotmeter still has a legitimate though secondary role, that of determining speed through the water which a gps cannot do and thus, (by comparison with the gps speed) give means for estimating water current components in the direction of boat movement. Another important remaining use of the knotmeter is for dead reckoning position estimates in the event of gps failure or non availability. As for me, if I didn't already have a hole in my boat for the knotmeter, I wouldn't put one there now. GPS velocity readout is the way to go for over the bottom speed. Period!
