1 gallon portable fuel tank...?
Nov 30, 2024
11
Catalina 22 Dana Point
Hello again,
I'm installing a Suzuki 2.5 on my inflatable and will be adding a fitting for an external fuel fuel tank. I'd like a 1 gallon fuel tank, unfortunately, the smallest Ive been able to find is a 3 gallon. Does anyone know of a 1 gallon portable fuel tank?
Mar 26, 2011
3,793
Corsair F-24 MK I Deale, MD
I think you will find that the internal tank is enough for such a small motor. One less thing to take up space in a small dinghy, one less them to load.
I had a 3.5 merc on my dinghy for my cruising cat (on davits). If we were going far we would grab 1-gallon jerry can, but 95% of the time there was no need and it saved space/weight just using the integral tank. And if your mother ship is a 22 feet, the inflatable must be small.
I think they don't exist because they are not wanted. I have a 2+ gallon Surecan that I like very much. Nearly impossible to spill. Not like other CARB cans.
Jan 8, 2025
179
Compac 16 Pensacola, FL
I looked on line for, and found, a one-gallon gas can but it wasn't set up for a hose and I can't at the moment find it. I thought I'd bookmarked it but doesn't seem I have. There is also a video on line showing how to install a hose fitting onto a plastic gas can but I don't have that link at hand either. At least a solution is out there -- somewhere.
Likes: Migolito
Hunter 30_88-94 Ipswich, Ma MA
Agree with thinwater. We have a 3.5 merc also which uses very little fuel. Granted, our main use is back and forth to our mooring, but if we go exploring, a one gallon container is easy to take along.
May 24, 2004
7,193
CC 30 South Florida
The internal tank when full should provide ample run time. If you want to carry a reserve for emergencies take a small gas can and a funnel.
Jun 14, 2010
2,387
You can go for hours on the internal tank. It will be plenty. The suzuki 2.5 sips fuel.
PS - very tiny jets in those carbs so I recommend you ALWAYS use a fuel stabilizer and non-ethanol fuel (or TruFuel). TrueFuel is expensive but worth it if it avoids servicing the carb, and you won’t use more than about 3 or 4 quarts all summer.
Mar 26, 2011
3,793
Another trick some folk use is to carry 500-1000 ml in a Sig-type hiking fuel bottle. Small, enough for back-up, no-spill. I carry my stove fuel in Sig-type aluminum bottles. I have a few left over from my hiking and mountaineering days.
May 2, 2020
40
Westerly Conway MKII 36 Indian Rocks Beach
Hello again,
Walmart has 1 gallon fuel jerricans. I have one for my Honda 2.0
