F
Frank Ross
I have been searching for a C22 swing keel or C25 WB. I checked out a C22 swing keel this weekend and under the cabin floor boards I saw some cracks that were about 1/32to 1/16 inch wide between the hull and what I would call rib like structures that are at 90 degrees from the swing keel trunk. These are not hair line cracks and extended about six inches along the hull/rib like structure junction. These "ribs" were part of the original design and not after thoughts or repairs. The boat was in great condition otherwise. There was another set aftward near the companionway that exhibited the same symptoms. Are these cracks a symptom of a more serious problem like improper lifting or supporting of the swing keel???? Thanks
