07 H-36 front water tank sender
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
The gauge reads empty but when take out and move up down it register on gauge works fine but back in tank reads empty
Dec 19, 2006
5,832
I removed the float and put a bucket of water and doesn’t float but when move it by hand it works as should so I guess needs replace.
But I tried coating it with flex seal and yes it floats again so I just replaced holding overboard macerator and other work needing to be done I am going to see how the flex seal works until I get new one.
Aug 18, 2018
146
Hunter 410 MDR
Order a new one from KUS, (weema replacements) they should still be less than $100.
Once the float is that saturated forget it and the float alone was not replaceable on the old ones.
I didn't know this happened in water tanks, my experience is from a diesel tank sender floats getting saturated.
