Air Conditioning Salt Water Cooling
PJL
Apr 22, 2014
55
Hunter 42 Nuevo Vallarta, Mexico
This applies to any boat having an air conditioner with salt water cooling. In cool waters this may not make any difference... However, in tropical waters the temperature is high and MANY more things want to grow in it. Because of this I must have the heat exchanger flushed every couple of years. Salt and dirt plate onto it and reduce its ability to cool. Consequently, the A/C will shut down with a High Pressure Fault (HPF).
The other area for trouble is the salt water filter. Small ones, typically builder installed, clog frequently due to things growing in the warm water; which causes the A/C unit to also get an HPF. I replaced the original filter with the GROCO ARG-750. That said, any large, easy to clean, filter will be acceptable. If the filter has a Stainless filter element, keep in mind the possibility of having to replace it frequently due do other boats introducing stray electric currents in the water and causing electrolysis.
At times, with the original filter, the element had to be replaced every few weeks. At other times it would last a year. Just depended on the boats near by. Some don't have their electrical systems well configured and grounded.
JamesG161
Feb 14, 2014
8,088
Hunter 430 Waveland, MS
I use this on my ARG - 750
1) close thru hull valve
2) remove strainer cap
3 Put on this cap.
4) attach shore water garden hose
5) Open thu hull valve and slowly back flush line
here is where I bought mine
Jim...
Likes: BigEasy
JamesG161
Feb 14, 2014
8,088
The small is not available, so just ordered this one.
has a shutoff valve in that one
Jim...
Jun 21, 2004
3,214
Beneteau 343 Slidell, LA
The TRAC flush cap is a great accessory. Simple to use for occasional flushing of water lines & condenser cooling lines as well as purging air from the circulating system if the pump doesn’t prime itself.
Likes: JamesG161
Feb 10, 2004
4,246
Hunter 40.5 Warwick, RI
I made my own flushing caps for my Groco ARG-750 and ARG-1000 filters 25 years ago using standard plumbing fittings. I use them for winterizing by flushing with fresh water and then running antifreeze through the systems- A/C and engines.
