-Catalina 22.
-Regular bunk style trailer. (1 bunk on each side).
-"V" guides for the keel that are bigger in back and come to a few inches in front.
-Do have an extension on the trailer that gives like 7' elongated, but when I tried it, it bottomed out on the cement and I had to stop.
-Regular winch on trailer. No power, no special features just a trailer winch. (Think it should be pulling from below also, while now its pulling from above? Not sure why any of it is like it is?)
I posted the photo of the boat as it was when I bought it from owner late last year... so you can see where the bow eye is situated on the trailer. I don't know how he got it up to there ever.. or why it is like that?
So I knew this time would come and I wouldn't know what to do. When I took the boat off the trailer and into the lake, the bow eye got caught up on the bow stop and was holding the whole boat up by it for 10 seconds of so until I went far enough in the water to get the whole boat off of the darn thing. My truck was pretty far into the water at this point but was only way I could figure out to get the bow eye "unhooked" from the bow stop. I figured this is what would happen here too and It unfortunately was. Seems fine but I need to change either my technique or my actual bow eye placement or maybe move the bow stop up on the trailer... or get a new trailer cause it ain't gonna be easy on the trailer I have to do that.
Am I missing something or doing something wrong... or is it the bow eye that sit right on top of the bow stop that is the whole problem and just an impossible situation as it is right now? I attempted to get the boat on the trailer and the bow eye was like 2' lower than the bow stop and didn't seem even close to getting up there without trying to pull the boat up that whole way, out of the water, with the winch to force it up? Didn't really want to have to do or try that until I knew I might need to.
The ramp is not particularly steep... I'd say its a normal angled ramp that most everyone else uses for their sailboats. There is also a ramp that is much steeper at the marina but that one looks scary and I actually..... Im thinking I might need an even LESS steep ramp to make my trailer work? There might be a less steep ramp on the other side of the the lake if anyone thinks that would be best? (I can flip my trailer hitch on my truck (u haul) so its in the higher (~6" higher..?) and maybe the trailer wont bottom out on the way into the ramp but I'm not sure this extension would even help my situation? Might even make it worse...? cant tell...
If I back any further in the water to get the bow eye close to the bow stop....the trailer will be so far in the boat will be completely floating on the water and not really touching any of the bunks.
So i don't know what the answer here is to make it work as it. The trailer is illegally parked at the boat ramp and I need to get the boat out in a few days or it'll prob be towed out?
any insight would be greatly appreciated!!
I
I
