Recommendation on Fans
Oct 7, 2025
42
Catalina 22 Chesapeake
I am getting close to finally getting my C22 in the water.
Does anyone have recommendations on dc wired or rechargeable battery fans? I would like 3 or 4 to use as needed.
Nov 6, 2006
10,220
I am a fan (!?) of Caframo fans. Low power draw and low noise. I have one of these in the saloon and I love it. I didn't believe the power numbers from the manufacturer so I measured and their numbers are good.. I like that it has a timer so it can be set to turn off after folks are asleep and the boat cools down. Kinda expensive but worth it in my opinion.
Amazon.com: SEEKR Sirocco II™ Fan from by Caframo. 12V/24V Auto-Sensing DC, Omnidirectional Low-Power Draw Fan for Boats and RVs. Hardwire Installation Required. Made in Canada. Black. : Clothing, Shoes & Jewelry
Jun 21, 2004
3,137
Beneteau 343 Slidell, LA
I installed four Hella two speed fans approximately 10 years ago; two in salon & one in each berth area. Quiet operation & relatively low power consumption.
Likes: RKenSailor
We have several Hella fans and like them because they are very quiet. We also have a Caframo 757 fan which does a better job of moving air for less money, however they are noise and the blades are exposed. Having some experience with the blades striking my fingers, this is not a big issue for teenage or adult sized hands, tiny hands may feel the blades more but there won't be any lasting damage.
Likes: RKenSailor
JBP-PA
Apr 29, 2022
792
Jeanneau Tonic 23 Erie, PA
I love these fans. I've tried several and these are still my favorite. They will run a couple days on low and are nearly silent, perfect to have a breeze while you are sleeping. You can put them anywhere or hang them or affix them on a screw. The 7 inch size is the one. The smaller one works but it's a little whiny.
I also have a Caframo Ultimate and a Caframo Bora which might be a little stronger, but are much louder.
Apr 22, 2011
975
Hunter 27 Pecan Grove, Oriental, NC
Amazon.com. I have two of these and one of them has run 24/7 for over 2 years on low speed. I leave it plugged into the USB receptacle to lessen the chance of mold developing. They are very quiet and draw very little current.
Likes: JBP-PA
