Luddite Battery Replacement
Aug 17, 2010
374
Oday 35 Barrington / Warwick RI
After six years and one month, it seems that my house bank, consisting of TWO Duracell Group size 31 Model # 31DCX (mfg 6/20), has finally bit the dust. Their periodic consumption of distilled water has gone up significantly, and the other day in a critical situation, they failed to start. Yesterday, I added a total of about half a GALLON of distilled water to top off all three batteries, when I usually use less than 500 ml during a season.
The situation was after spending a night at anchor in the Kickamuit River, I was trying to exit the Kickamuit under sail. While I was approaching R N "6", with the current against me, the wind died, or I was in the lee of the houses on the west bank, and the boat speed dropped to 0.4kt against a 0.5kt current.
I was fortunate to have bank 2 fully charged, so I quickly dove below deck, flipped the switch to bank 2, and got back to the helm. I started the engine, and got back on course without running aground.
Anyway, I will be looking for new Flooded Lead Acid batteries for my vessel. I'll replace the start battery while I am there, because I would like to keep them all about the same age. Right now, I am looking at 2 EverStart Group 29 Deep Cycle batteries, because I can't find Group 31 Batteries anywhere in southeastern Mass or RI.
During the season, I keep the batteries charged by a 100 Watt Solar Panel, which is then connected to a Victron Energy MPPT Controller, which is set up for Flooded Lead Acid Batteries.
If it helps, here is a schematic of the charging setup of my primary electrical system;
TLDR; I am looking for battery recommendations. I am currently planning on 2 EverStart Maxx Group 29DC batteries from Wally-world for ~$260.
Change my mind!
1,326
Pearson P30 202 Ottawa
I have and can recommend 2 6v golf cart batteries, wire them in series, the ones I use are said to supply 230 amps/hours. Way more than needed, they are about 6 years old, I do have to top them
Once in a while with distilled water, but maybe once a season so far.
They are extremely heavy and do take more room, but for us it is an excellent trade off
Aug 17, 2010
374
Yes, thanks for that. Unfortunately I am space limited on my boat. I could fit the Grp 31 batteries, but with about a quarter inch of space between the top of the batteries and the compartment that they occupy. Golf cart batteries will simply not fit.
Aug 17, 2010
374
I went to Costco today, and bought 3 Interstate Marine Deep Cycle batteries; 2 Group 31, and 1 Group 24. The total, including MA Tax, was $361.22
Sep 25, 2008
7,704
Alden 50 Sarasota, Florida
Be aware that because they are not of similar capacity, charging them becomes a bit more complicated. Ask if you need more info.
Aug 17, 2010
374
The two Grp 31 are Bank 1 (House) and the single Grp 24 is bank 2 (Spare). See the diagram of my charging system above for details.
Sep 25, 2008
7,704
I looked but hard to follow. Just wanted to pass along the suggestion which I infer you already understood.
Likes: eherlihy
Feb 6, 1998
11,761
Change my mind!
G-29 is a G-31 with a Wal-Mart group size. If the serial # on the batts at Walmart starts with EP they are made by East Penn. If it does not start with EP run away.
Likes: eherlihy
Aug 17, 2010
374
Can you shed any light on who makes Interstate Group 31 Marine Batteries?
[EDIT] NVM - Google AI tells me that they were probably made by Johnson Controls (now known as Clarios).
Interstate is a marketing and distribution company. The exact manufacturer for any specific Group 31 marine battery can vary by model (flooded deep-cycle vs. AGM), production date, and supply agreements. It is often difficult or impossible to identify the maker from the Interstate branding alone, as the batteries are private-labeled.
