Bulkhead Vinyl bead trim
Oct 7, 2025
42
Catalina 22 Chesapeake
I'm replacing my bulkheads and my vinyl trim is shot. Any recommendations on a good replacement vinyl bead trim? I don't even know if what I removed was original and what it should look like. Also, don't know if it is better for the trim to match the white cabin/hull or the brown teak'ish bulkheads.
Any recommendation from those who have done this is appreciated.
Sep 30, 2013
3,692
Mine came with teak trim. I thought they all did.
We put black vinyl edge trim on the plywood edges in our Albin Vega. I can definitely say it looked a lot better than the metallic gold trim the factory used. :biggrin:
