Oceanis 281 bilge pump
Jan 30, 2022
4
Beneteau Oceanis 281 Canton
My Oceanis 281 bilge pump runs but does not pump water. What could the problem be?
Several possible explanations.
The hose is clogged and water can't get through.
It is normal behavior. The common bilge pumps in our boats push water out of the bilge, which works fine up to a point. Once the water level gets low the pump starts pushing air, which it does poorly. The float switch turns the pump off because the water level has dropped and any water in the hose flows back down into the bilge. The solution is to use a diaphragm pump. However these are more expensive and there is always some residual water in the bilge, best removed with a sponge.
Likes: BigEasy
Jun 7, 2026
1
Beneteau 352 1999 352 FT. LAUDERDALE
The water reaches sensor, pumps out just small amount that reached sensor then many pumps are programmed to run for a full minute at every cycle so it will pump nothing for the remainder of that cycle.
